Published
March 16, 2022
Time to read
6 Minutes
DeNoise AI v3.6 - Updated RAW model, refreshed file saving experience, and stability improvements
DeNoise AI v3.6 at a glance
  • Updated RAW model - We’ve added support for additional RAW formats, including Fujifilm and DJI, as well as great support for linear DNG and non-RAW file formats.
  • Refreshed file saving experience - In addition to improving the overall DeNoise AI standalone file saving experience, we’ve added the ability to overwrite files.
  • Stability improvements and bug fixes - Fixes include no longer have the same auto settings applied in batch view, elimination of various memory leaks, and an issue preventing closing DeNoise AI when no image(s) are loaded
Download DeNoise AI v3.6
Windows | MacOS
Release Notes
Updated RAW model
DeNoise AI v3.6 RAW model applying noise reduction to a Fujifilm X100V .RAF file | Source: Carey Rose via DPReview
We initially released the RAW model with DeNoise AI v3.3, providing remarkable noise reduction by analyzing the original image data found in RAW files. That original RAW model already supported many camera manufacturers and models (1, 2), but we wanted to expand on that. Since then, we’ve trained an updated RAW model analogue that adds support for additional camera models, most notably those by Fujifilm, as well as improving our support for linear DNG images. The latter format now allows users to use DeNoise AI with RAW images taken by mobile phones, such as Apple’s iPhone, which are saved as DNG.
We’ve also extended support of this updated RAW model to non-RAW file formats such as TIFF, JPEG, and PNG. We strongly advise that you do not apply any sharpening or noise reduction in advance if you plan on using the updated RAW model with non-RAW formats.
When we released DeNoise AI v3.3, we included a change to help prevent users from accidentally overwriting their original file in certain circumstances. Unfortunately, that change inadvertently broke the external editor workflow for Mac users using non-Adobe host applications such as Capture One and Apple Photos, preventing them from overwriting the image file sent to DeNoise AI from the host application. With the new Save dialog box in DeNoise AI v3.6, users can now select to overwrite the image sent to the app, thereby restoring the correct round-trip workflow with the host application. Adobe Lightroom and Photoshop users will not experience any changes to their existing workflows when sending photos from those host apps to DeNoise AI.
We’ve also redesigned the overall Save dialog box to be more clear, providing you with everything you need to determine which file format to output, as well as the destination to save that file to.
DeNoise AI v3.6 also includes a number of helpful bug fixes and stability improvements. Notably, we resolved an issue where the same Auto settings would be applied to all images in a batch sequence. We also fixed an issue that prevented users from properly closing DeNoise AI when no images were loaded. You should also experience improved stability and performance thanks to resolved memory leak and crash issues.
Latest Articles
July 31, 2025
Upscayl Alternative for AI Image Upscaling
July 26, 2025
4 Landscape Photography Tips to Elevate Your Shots
July 22, 2025
How Topaz Labs’ Bloom & Astra Help Bring Concepts into 4K Reality
