Back to Learning Center
Published
November 10, 2021
Time to read
Gigapixel AI v5.7 - Updated Standard AI model with Auto settings, improved cropping experience, and lots of usability improvements
Gigapixel AI v5.7 at a glance
  • Updated Standard AI model with Auto settings - Our newly trained Standard model provides sharper edge details and higher overall quality when upscaling a broad range of photos.
  • Improved cropping experience - We’ve improved the cropping tools to be more intuitive by presenting the most important settings you’ll need to refine your composition exactly the way you want it to be.
  • Lots of bug fixes and usability improvements - New AI model tooltips, improvements with keyboard shortcuts & scrolling, and a host of bug fixes make Gigapixel AI more convenient than ever before.
Download Gigapixel AI v5.7
Windows | macOS
Release Notes
Original photo
6x upscale using the updated Standard model in Gigapixel AI
We've made significant improvements to both the upsampling and parameter selection models of the Standard mode in Gigapixel AI. The new upsampling model is trained with a wider variety of datasets and extra optimization objectives. The parameter selection model applies a new structure, which better estimates the noise and blur level of a photo.You can use both models together by enabling the new General mode Auto setting, which provides improved quality for many photos without degradation.
Cropping is an important part of the upscaling workflow, which is why we're excited to provide a better experience for that task. While a lot of the cropping improvements are under-the-hood, you can now lock the crop aspect ratio by holding down the Shift key, freeform crop dimensions can now be flipped, and ISO A4 has been added as a new aspect ratio preset.
Gigapixel AI v5.7 includes a host of bug fixes and usability improvements that should result in a more stable and streamlined user experience. Some of the improvements include fixing keyboard shortcuts on certain number fields, adding missing View mode shortcuts on macOS, fixing various layout bugs when resizing windows, improving the reliability of the Preview window under certain situations, and fixing the comparison view not updating when changing scale.
Latest Articles
July 9, 2025
April 14, 2025
January 12, 2023
