Published
October 19, 2022
Time to read
12 Minutes
Topaz Video AI v3.0: Rebuilt with a new stabilization model, smarter workflows, and improved video enhancement capabilities
Article outline
Read the Topaz Video AI v3.0 Release Notes
Introducing Topaz Video AI v3.0
Topaz Video AI gives you unlimited access to the world’s leading production-grade neural networks for video upscaling, de-interlacing, motion interpolation, and shake stabilization - all optimized for your local workstation.
We built Topaz Video AI v3.0 from the ground up to include new functionality, such as video stabilization, improved enhancement capabilities, and a better user experience. Using this new code base allows us to provide some of your most requested features, such as:
  • Stacking AI models
  • Running tasks in parallel with filter support
  • Command-line interface
  • Important performance and stability improvements
Pricing for Topaz Video AI
  • $299.00 for new customers, which includes one year of app updates.
  • Existing Video Enhance AI customers with an active license get Topaz Video AI v3.0 for free.
  • Existing Video Enhance AI customers without an active license can purchase an additional year of app updates for $149.00, which includes Topaz Video AI v.3.0.
Why we built Topaz Video AI v3.0
We originally built Video Enhance AI to improve the most common quality issues affecting videos, including de-interlacing footage, intelligent upscaling up to 8K resolution, and seamless frame rate conversion. Because it treats video as a series of constant rate images, it led to problems when the app’s AI models had to process variable frame rate footage, frame repeats, and scene changes. It also complicated our ability to develop new models to address stabilization or scene detection because they require multiple passes over the video.
To develop these new features and to continue innovating, we built the next generation of this app atop an entirely new code base and a brand new user interface with numerous functionality improvements, such as stacking multiple AI models, executing parallel tasks, and project queue filtering.
The new features included with Topaz Video AI v3.0 can be broken down into two categories:
  1. Improvements to usability
  2. New AI models
Stacking AI models
You can now enable more than one AI model in a single task, allowing for a more flexible workflow. For example, you can now upscale to 4K resolution while enabling stabilization and adding grain.
Users can now execute multiple tasks simultaneously, allowing for a more efficient workflow. You can run different previews from multiple input video files with varying settings and export several projects simultaneously.
You can also use the new filtering options to display process jobs for the selected video file or all loaded video files and filter by output preview tasks, export tasks, or both.
Command line interface
Topaz Video AI v3.0 now supports executing scripts using a command line interface. This is designed for advanced users comfortable working in such an environment and offers great flexibility in customizing various scripted processes to execute. We highly recommend using the app’s user interface for those not comfortable working in a command terminal.
For example, the script command in the screenshot above will issue the following instructions:
  1. Hide the FFmpeg startup banner
  2. Enable hardware acceleration, and uses the hevc_qsv encoder (H.265)
  3. Use the main profile with the medium preset for the encoder
  4. Set the CRF to 19
  5. Set the output pixel format to yuv420p
  6. Create 100% fragmented output, allowing the file to be read if the processing is interrupted
  7. Upscale 2x using Artemis v13 on GPU 0
Learn more about using the new command line interface on our Support Center.
Topaz Video AI v3.0 also includes many new performance and stability improvements such as:
  • Support for hardware encoding on all platforms for H264, H265, and AV1 (when available), along with higher-bit output formats such as ProRes 444.
  • Improved colorspace support and color accuracy
  • Up to 16-bit color depth now supported
  • New cropping tool
  • New letterbox/pillarbox detection and removal tool
  • Improved Trim tool
  • Ability to set default preview and export preferences
  • Support for all aspect ratios, including vertical video
  • Offline support allowing usage of the app when not connected to the internet. An internet connection is required to download new AI models.
  • Ability to play preview videos in an external player app
New AI models
Stabilization model
The new stabilization model reduces shaky or jittery motion that often results from an unstable camera. It does so in two steps:
  1. It estimates the camera movements between the frames, and
  2. It transforms each frame so that camera movements appear to be smoother.
Traditional methods rely on finding and matching individual feature points between frames to determine the camera motion. Still, it may be unreliable if the frames contain challenging scenes such as low contrast regions, illumination changes, motion blur, and moving objects.
The new stabilization AI model considers the entire frame instead of an individual point. We trained the model with challenging video samples to perform better than the traditional feature-matching algorithm.
Most stabilization methods need to crop the composition to remove the missing regions created after transforming the frames, which can affect the footage's intended framing. Therefore, in addition to the Auto-Crop option, Topaz Video AI offers Full-Frame stabilization, which generates the missing region using neighboring frames and AI models.
Topaz Video AI also offers options for correcting rolling shutter effect and reducing jittery motions. The "Reduce Jitter Motions" option uses another AI model to reduce the spatial jitters among the neighboring frames, minimizing 3D camera rotations and parallax effects.
Apollo slow motion model
Like our original slow-motion AI models, Chronos and Chronos Fast, the new Apollo model interpolates between frames to create a slow-motion video and convert frame rate. However, the Apollo model is trained to handle non-linear motion and motion blurs. It considers four adjacent frames to estimate the motion of objects between those frames, which helps the model understand the non-linearity of the motion and interpolate in-between points accordingly.
The Apollo model is best suited to slow down the motion in videos containing non-mechanical movements (e.g., human or animal movements or hand-held camera footage). We recommend trying the Apollo model before Chronos or Chronos Fast if the video has any blurriness.
Try Topaz Video AI v.3.0 today
Topaz Video AI v3.0 is the next generation of AI-powered video enhancement. Completely rebuilt from the ground up, it delivers greater quality, functionality, and flexibility thanks to our new user interface and AI models. Download a free trial of Topaz Video AI today to see it for yourself.
Latest Articles
July 22, 2025
How Topaz Labs’ Bloom & Astra Bring Concepts into 4K Reality
July 16, 2025
The Best Remini AI Alternative
July 9, 2025
Published
October 19, 2022
Time to read
12 Minutes
Article outline
  2. New AI models
Stacking AI models
  • New cropping tool
New AI models
Stabilization model
Latest Articles
July 22, 2025
July 16, 2025
July 9, 2025
