How they compare
Best for Enhancement
Topaz Video
topazlabs.com
DaVinci Resolve
blackmagicdesign.com
Purpose
What the tool is built for
Purpose-built AI video enhancement. Every feature, model, and update exists to produce the highest-quality enhanced output possible. Used as a standalone tool or as a pre-processing step before editing.
Dedicated enhancer
Complete post-production suite editing, color grading, VFX, Fusion motion graphics, and Fairlight audio all in one application. The industry standard NLE for professional finishing.
Full production suite
Output Quality
Enhancement & detail recovery
19 AI models trained exclusively on video enhancement denoising, upscaling, face recovery, and frame interpolation. Excels at recovering heavily degraded, compressed, or low-resolution footage. Trusted by Netflix, Apple, Adobe, and Higgsfield AI.
Best for degraded footage
Neural Engine tools including SuperScale, UltraNR, and UltraSharpen deliver strong results when working with high-quality source material. Works best when footage is already clean and well-exposed.
Best for clean source footage
AI Model Depth
Specialization & control
19 purpose-built models: Starlight for restoration, Nyx and Nyx XL for denoising, Iris for faces, Rhea and Rhea XL for upscaling, Aion for extreme slow motion, Proteus, Artemis, Gaia, Theia, Apollo, Chronos, and more. Precise per-clip model selection.
19 dedicated models
SuperScale for upscaling, UltraNR for noise reduction, UltraSharpen and Motion Deblur for sharpness integrated directly into the editing and color pipeline without leaving Resolve.
4 integrated tools
Max Resolution
Highest output ceiling
High-accuracy enhancements up to 4K across a wide range of content genAI, live action, and animated footage.
✓ Up to 4K
Up to 32K resolution at 120fps in DaVinci Resolve Studio. SuperScale can upscale HD sources to 4K and 8K.
Up to 32K (Studio)
Processing
Local, cloud, or both
Local GPU processing keeps sensitive files on your machine. Cloud processing also available via Topaz Studio offload demanding jobs without tying up your hardware.
✓ Local + Cloud
Local GPU processing only. Blackmagic Cloud available for project collaboration but not for offloading enhancement rendering.
Local only
Platform Support
OS & access options
Windows and macOS desktop app. Web-based access via Topaz Studio for cloud rendering and team workflows.
✓ Win / Mac / Web
Windows, macOS, and Linux. No web-based access. AI Neural Engine features require the paid Studio license.
Win / Mac / Linux
Commercial Use
Licensing for professional work
Full commercial usage rights on Pro plans. Personal plans include limited commercial use for organizations under $1M annual revenue.
✓ Full on Pro plan
No commercial use restrictions. All output from DaVinci Resolve is fully yours regardless of plan tier.
✓ Unrestricted
Workflow Integration
How they fit together
Runs as an OpenFX plugin inside DaVinci Resolve Studio (Beta) apply Topaz Enhancement and Motion Deblur models as a node in Resolve's color or edit workspace. Also available as a standalone app for pre-processing before you bring footage into Resolve, with access to the full 19-model suite.
Works inside Resolve
The ideal finishing environment for Topaz-enhanced footage. Edit, color grade, mix audio, and add VFX to footage that Topaz has already restored and sharpened with Hollywood-grade color tools and a professional timeline.
The finishing environment
Pricing
Cost & plan structure
Personal plan from $25/mo (billed annually). Pro plan from $58/mo with full commercial use and local Starlight models. Topaz Studio bundles all Topaz apps from $37/mo.
✓ Full suite available
Free version available with no AI features. Studio is a $295 one-time license with all future updates included no subscription required.
$295 one-time
The Bottom Line
Topaz Video and DaVinci Resolve aren't competing for the same job they're built for different stages of the same workflow. Topaz Video is where you bring footage back to life: restoring, denoising, upscaling, and sharpening before a single edit is made. DaVinci Resolve is where you finish it: cutting, grading, mixing, and delivering. The most powerful professional workflows use both Topaz Video as the enhancement engine that feeds the best possible footage into DaVinci Resolve's world-class finishing environment. The good news: Topaz Video runs as a plugin directly inside DaVinci Resolve Studio, so you don't have to choose.
